1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Knyazev : TDU2 Universal Launcher [v3.6]
Discussion in 'TDU2 - Mod Tools & Support' started by Knyazev, Nov 11, 2011.
  1. lontrafag
    lontrafag Rookie
    2
    Brazil
    Hello, and sorry to bump up this thread again, but I have some issue with Universal Launcher, seems to be a old issue to be honest, looks like the bug "Cannot create a file when that file already exists." was back again in my app.
    It's the lastest version (3.6) and it's running fine before today, the bug came from nowhere, I even reinstall .NET Framework 3.5 on Windows 10. Here is the error dump:
    Errors.log file:
    Code:
    13-Sep-17 9:12 PM:    Process has exited, so the requested information is not available.
    System.InvalidOperationException: Process has exited, so the requested information is not available.
       at System.Diagnostics.Process.EnsureState(State state)
       at System.Diagnostics.Process.get_MainWindowHandle()
       at _UL_Functions._UL_Function.RunGame(Boolean console, String hash, String mode)
    .NET Framework dump:
    Code:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.IO.IOException: Cannot create a file when that file already exists.
       at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
       at System.IO.File.Move(String sourceFileName, String destFileName)
       at TDU2_Universal_Launcher._UL_MainWindow._UL_MainWindow_Load(Object sender, EventArgs e)
       at System.Windows.Forms.Form.OnLoad(EventArgs e)
       at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
       at System.Windows.Forms.Control.CreateControl()
       at System.Windows.Forms.Control.WmShowWindow(Message& m)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 2.0.0.0
        Win32 Version: 2.0.50727.8784 (WinRel.050727-8700)
        CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
        Assembly Version: 3.6.0.1
        Win32 Version: 3.6.0.1
        CodeBase: file:///D:/Mods/TDU2_Universal_Launcher_v3.6/TDU2_Universal_Launcher.exe
    System
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Xml
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Drawing
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    h54gb8lv
    Accessibility
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    {92bdde5d-a673-496c-a6cc-0eea6ac20934}
        Assembly Version: 0.0.0.0
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    The batch file is not working and running in administrator causes to not locate the Universal Launcher.
    Hope it helps in something.
    If is something wrong with my machine, just let me know and thanks in advance.
  2. MagicV8
    MagicV8 Well-Known Member
    898
    Drivers Paradise
    I don't know anything about your problem, especially about Windows 10 (I'm using WIn7), but there are some threads about Windows 10 problems here (TDU1 and/or TDU2, cannot remember actually).
    Perhaps you could find a solution there.
  3. lontrafag
    lontrafag Rookie
    2
    Brazil
    The weird thing is the Universal Launcher was working well on W10 before the error, even on developer's website says compatibility for the system.
    But anyways, I will look for threads about TDU problems on W10.
  4. ClarenceCallahan
    2
    Rockport
    This one don't work. Everytime I press the play button, window goes black and then back on the desktop. How to fix?
  5. MichaelB450
    MichaelB450 Retired sound mod maker...
    354
    San Diego, California
    Do I need .NET Framework 3.5? Or does .NET Framework 4.5 work perfectly fine?
  6. binbow
    binbow Well-Known Member
    715
    Tokyo
    The .NET Framework 3.5 is required.
  7. MichaelB450
    354
    I was never able to get it installed, no matter what...
    Edit:
    It appears to already be installed...
  8. MichaelB450
    354
    Okay so it appears that the Universal Launcher does have a few issues now. As of recently the game doesn't close correctly after I enter and exit it 6 times. And I also did recording with OBS while playing the game and before exiting it. On the 6th exit my GPU freaks out and goes between idle clock and base clock when I open any program on my computer (including windows explorer). So I believe it has something to do with the Universal Launcher not having any update over the past year.
    I don't have this issue with any other game, even The Crew doesn't do this and it's the most resource taxing game that I play. Anybody else having the issue I mention above? The only way for me to clear out the issue is to restart my PC and that sometimes means doing that once or twice a day, which is very inconvenient...
    System specs:
    - Gigabyte GTX 1060 3GB
    - Intel i5 3570K (stable 3.8GHz OC)
    - 8GB of DDR3 ram
    #188 MichaelB450, Feb 9, 2018
  9. WNTL
    WNTL Rookie
    3
    All over the world
    Hello,
    launcher was working perfect, and today after I installed carpack 1.8 it asks me for serial number. What the heck. Anyone had similiar issue?
  10. Metal.Domination
    1
    all links are offline anyone can help me
  11. Ramon1991cobra
    Ramon1991cobra Active Member
    110
    Buenos Aires
  12. fafzakas
    fafzakas New Member
    21
    madrid
    Hi.
    When I try to lunch univerdsal launcher, they give me a erro.
    this is the error
    /*04/07/2018 15:36: Error en el documento XML (10, 1:cool:.
    System.InvalidOperationException: Error en el documento XML (10, 1:cool:. ---> System.Xml.XmlException: Declaración XML inesperada. La declaración XML debe ser el primer nodo del documento y no pueden aparecer espacios en blanco delante. Línea 10, posición 18.
    en System.Xml.XmlTextReaderImpl.Throw(Exception e)
    en System.Xml.XmlTextReaderImpl.ParsePI(BufferBuilder piInDtdStringBuilder)
    en System.Xml.XmlTextReaderImpl.ParseDocumentContent()
    en System.Xml.XmlReader.ReadEndElement()
    en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReader_UL_Settings.Read2__UL_Settings(Boolean isNullable, Boolean checkType)
    en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReader_UL_Settings.Read3__UL_Settings()
    --- Fin del seguimiento de la pila de la excepción interna ---
    en System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
    en System.Xml.Serialization.XmlSerializer.Deserialize(TextReader textReader)
    en _UL_Settings.UL_Properties.ReadXml()
    en TDU2_Universal_Launcher.Program.Main(String[] Args)*/
    what can i do?
  13. StarGT
    StarGT Ukrainian car modder
    2,165
    Ukraine,Nikolaev
    I have trouble with using texmod programm with TDU2 AutoPack ! ....Texmod not working
    Maybe somebody have this trouble too and find solution. Explain me please, thx
  14. Knyazev
    Knyazev Banned!
    156
    Russia, Kaliningrad
    Hello.
    Go to folder: C:\Users\*YOUR_USERNAME*\AppData\Local\i-Knyazev.ru\TDU2
    and delete the folder "Universal Launcher" and then start the Universal Launcher.
    StarGT likes this.
  15. StarGT
    2,165
    Ukraine,Nikolaev
    Help! - TDU2 AutoPack and Texmod
Share This Page
  • About Us
    Started back in 2007, our community has been around for a good while and throughout all this time our core focus has been to provide a fun and laid back place for the discussion of driving and racing games and gaming in general, along with freqent automotive and motorsport related chat too. So, no matter what style of player you are, from arcade thrills to hardcore sim-racer or free roam explorer to circuit hot lapper, if it's about driving or racing in some form then we're up for talking about it. And if you are a keen photo moder, virtual photographer, video creator or streamer, then feel free to share those too. Cheers!
  • Support our community!
    Running and maintaining a community like this is hard work, especially when it's done by a bunch of idiots! And so, if you enjoy visiting here and would like to help us out. We would really appreciate it! Thanks.
    Feed the duck!
