Page 1 of 2 12 Last
Results 1 to 20 of 22
  1. B1gSmurf is offline Rusted Banger
    Default Which HD TV Cable
    Hey guys, im probably going to buy an HD TV this week, but im not sure about the cables to use. I think the tv will be an HD Ready Samsung 32'' LCD .
    I've got the premium 360 with an cable included the one with the red-blue-green connectors is that good for an HD TV ? Can you put that cables onto the scart connector and then plug it into an HD TV ?
    Or do i have to buy a new cable set? Please tell me what i need.
    Thanks for your help guys !
  2. mellors_ is offline Banned
    Default Re: Which HD TV Cable
    if your cable has a red, green and blue cables on it , it is a component and will work fine and there will be 3 input holes in the back or side of the TV
  3. craigie is offline I have the...
    the cable that comes with the xbox 360 has 6 ends. All 6 of these form the componant HD input and will plug into the back of any HD tv with a componant input (the samsung should as the samsungs are very good when it comes to inputs)
    There is no need to buy any other cable and the cables will plug straight into the back - no need for a SCART input
    SCART inputs are not HD anyways but thats not the point
    Foo Fighters @ Wembley - 6th June
    Fatboy Slim @ O2 Wireless Festival 2008
  4. mellors_ is offline Banned
    Quote Originally Posted by craigie »
    thats what i meant but i am to tired to type too muchand it might be the same as my TV
  5. B1gSmurf is offline Rusted Banger
    Ok alright guys, i see what i need and thanks alot for your help.
    Im probably getting HD TV tonight
  6. JOk3r77 is offline Rusted Banger
    NO NO.....it's just five out of the six, Red, Green, Blue for picture and red and white for left and right sound. The yellow is for standard AV or Scart connector. Ensure the switch is set to HDTV and that you TV is set to component in. Set the dashboard video settings to the amount that your TV can handle(use the last set of numbers in the resolution on your tv documentation), for me my TV is 1366 x 766 (or something like that, so 720p is my best setting.
  7. Pherelas is offline I'm Going Slightly mad
    Quote Originally Posted by JOk3r77 »
    Was just about to say this. The HD bit is only really three becouse the other two are sound and while the two leads are good, the best is optical cable.
    But your question. If you have the one with 6 ends, thats the cable you want.
    [imglink]http://i147.photobucket.com/albums/r289/pherelas/SigCustom.jpg[/imglink]
    . . . . . . Why is it always a wrong number, what if there in the wrong house? . . . . . . .
  8. Rollin in an STi is offline Subie Owner
    i have the 5 of the 6 connecters plugged into my TV as its the only way i could that was left in the back (the surround system is in one, the PS3's composite (red,yellow,white) is connected to in the front which is input#2, and my 360 connected to input#3. but i switched the switch on the HDTV instead of reg TV, and adjust the settings on the dashboard, but my TV goes blank. So im just using the Red,Blue,green,Red,and White for better sound. lmao. I really need to upgrade my TV. LMAO
    To Finish First,
    First You Must Finish
  9. JOk3r77 is offline Rusted Banger
    Quote Originally Posted by Capn Wakka »
    Blank screen?.......Is your TV a High Definition ready model?......if so then you should not get a blank screen at all. Otherwise I don't know what to sya other than......hahahahaha (sorry!!)
  10. YeOldeTDUMan is offline working too much
    #10
    I use the supplied cable in the COMPONENT plugs on the back of my screen .... green, blue, red on the grey plugs for the picture (leaving the yellow dangling free) and then the pure white and red plugs for the sound, although I've also plugged a digital optical cable in the cable plug at the 360 end and then into my amp
    I'd rather be topless !
  11. Rollin in an STi is offline Subie Owner
    #11
    Quote Originally Posted by Hybrid_IV »
    that almost exactly how my set-up is Hybrid. Except pluging the Optical into an Amp, i have it plugged into my 5.1 Surround Sound.
    and to Joker77, i dont think my TV is HD ready. im not sure, i will have to find the manual (i hate reading manuals) to see, and possibly change settings if i have to
    To Finish First,
  12. craigie is offline I have the...
    #12
    this is what i meant but i didnt want to confuse him with 5s and 6s
    Does anyone know what just the Red and White (solid) cables are called (the ones that plug into the tv/sterio into speakers?
    i need to buy a new cable and i need the proper name
  13. mellors_ is offline Banned
    #13
    They are called stereo audio cables
  14. YeOldeTDUMan is offline working too much
    #14
    yes the solid red and white are good old fashioned stereo cables
    and when I mean I've plugged an optical cable into the amp for the sound ... the amp is 5.1 ... Yay!
  15. craigie is offline I have the...
    #15
    does anyone know where i can find a cable like this?:
    Attached Images Attached Images
  16. Who
    Who is offline It's not a tumor.
    #16
    i could do with summit like that. i need to plug in my 5.1. but i cant stretch the stereo output apart from the video... (i got a core so i only have Red White [audio] and Yellow [video])
    Formerly Crazed Dodgem/Lwsbrck
    I'm not dead!
  17. mellors_ is offline Banned
    #17
    i just cut the end of the audio cables coming out of my 360 and got to old double male composite cables and seletaped them and that made it long enough
  18. craigie is offline I have the...
    #18
    i need them to go out of my tv into my 5.1 surround sound
    at the moment the speakers are plugged into a headphone jack which isnt ideal
  19. YeOldeTDUMan is offline working too much
    #19
    looks like a straight photo to phono ... any tv/hifi retailer should be able to sell you one for a couple of quid
  20. JOk3r77 is offline Rusted Banger
    #20
    The lead is a 2x RCA Phono to RCA Phono. It can b e found in any electrical retailer (comet, currys, dixons heck even Argos). By putting the RCA phono leads from TV to your 5.1 system you will only ever have a stereo output even in pseudo 5.1 mode. If you have a Digital Input on the 5.1 (which I reckon you will have) then ideally you should get the Toslink cable (fibre optic cable) which is just a couple of quid if you look around carefully enough (usually markets are great for these bleeders). You will need to have the AV cable from premium 360 for the relevant connector. True 5.1 is great, stereo isn't that good to be honest.
Page 1 of 2 12 Last
