Page 1 of 2 12 Last
Results 1 to 20 of 23
  1. StrickenHAWK? is offline Car Aficianado
    Default I Have Problems.
    right here goes,
    just recently i wanted to start to use some mods again. so i stuck one in, got the error and closed the game. searched on here for a bit, found you have to put the magic map in. so i did that, and ever since i have had 2 problems.
    a) when i press T to talk, it lags. i type my message and press enter, and lags again, and sends the message, and all is good again.
    b) people will be talking to me, and are right next to me, and i cant see them. the reason i know they are right next to me is 1. they are talking saying they are, and 2 i look on the map and suprise suprise, there they are, right next to me.
    so if anyone has a fix, or knows how to fix it, or even has the problem, please post up and say!
    thanks in advamce.
  2. SLRRR is offline Ace
    Strange i can talk drive with other etc... with magic map
  3. Fridge Magnet Rabbit is offline Manchester Racer Kid
    EVIL, do you have the Megapack? the magic map is designed for Megapack users and the lag is probably just your internet
    Nugget of the week: week 27!!
    1x Winner of 'What car is this?'
    TDU1: Paltala
    TDU2: Paltala
    TDU2 Forums: Paltala
    Recurring Theme much? :P
  4. StrickenHAWK? is offline Car Aficianado
    no, i dont have megapack.
  5. Gunned_Down666 is offline Burnout King
    i had same problem as this. ive had it twice. to fix the only way i know of is to unistall your game and reinstall it and that seems to fix it.
  6. StrickenHAWK? is offline Car Aficianado
    ok, i will try that. thanks in advance!
  7. StrickenHAWK? is offline Car Aficianado
    right. this is starting to get annoying now. i installed NFSU2 last night as it is one of my favourite games of all time. so at the menu and when i press esc to pause, it will freeze for a few seconds, and then it will be fine. same coming out of a shop, etc, etc. i am getting really annoyed, and ill do a defrag tomorrow and see if it will work.
  8. NitroBlueUK is offline Exoticar Driver
    Check In Your Nvidia Drivers That For The Game The Transparency AA Is Disabled As It Caused Mine To Lag Out Like That In Vista
    [imglink]http://img87.imageshack.us/img87/2800/signewbu2.jpg[/imglink]
    Practice Safe Sex Go Screw Yourself!!!!
  9. StrickenHAWK? is offline Car Aficianado
    but come on...its nfsu2! lol, ill try that, and post back.
    EDIT: where do i change that?
  10. RRacer is offline Go as fast as you can!
    #10
    i have no megapack and mine works fine
    and nfsu2 sucks get carbon or prostreet (although i played u2 for a long long time)
    Proud owner of a Fanatec 911GT3RS and Clubsport pedals.
  11. StrickenHAWK? is offline Car Aficianado
    #11
    i dont have a megapack either.
  12. NitroBlueUK is offline Exoticar Driver
    #12
    Open The NVidia Control Panel
    Select Advanced If It Asks
    Click On Manage 3D Settings
    Select The Program Settings Tab
    Select NFSU2 From The Drop Down Box
    And Where It Says Antialiasing - Transparency Select Off From The Drop Down List
    Click Apply And The Settings Will Be Saved
  13. StrickenHAWK? is offline Car Aficianado
    #13
    nope, no difference.
  14. StrickenHAWK? is offline Car Aficianado
    #14
    i am getting it on all of my games now. i dont know what to do! please help!
  15. NitroBlueUK is offline Exoticar Driver
  16. StrickenHAWK? is offline Car Aficianado
    #16
    i cant run it for some reason i am on Windows 7 atm, but i was getting it previously on XP as well. thanks though!
  17. Sponge is offline Spongify
    #17
    The magic map would NOT affect other games.
    Your problem is not with TDU. Try a system restore. If that fails a format may be at hand (seeing as you have Windows 7 - you should already know how to format)
    SOOAG - Smug Owner of a G27
    Winner POTW: Week 28, 53
    Proud Owner Of TDU's FIRST Manual Shift Gallardo
    Flickr
    ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ
  18. Recon is offline Wanted - This Man
    #18
    nvidia likes to update their hardware alot, so it might need to be updated. if not, something i did when i bought Left 4 Dead, in your Nvidia contol panel you should have the option to use the preference bar on graphics settings. You may not think that their is much of a difference when it is set to performance or quality, but their is.
    :bananadance2:Get the Gamer's Pass!
  19. Immelmann is offline Custom User Title
    #19
    Haha, the title grabbed my attention. I would suggest making sure you have the right magic map.
  20. StrickenHAWK? is offline Car Aficianado
    #20
    when i installed W7 - i thought i lost my hard drive with XP on. googled, found solution. prior to that, i looked for a system restore. there were none, since i had just installed W7. i was getting it on XP as well. so i dont know whats wrong there.
    a format - i dont want to loose all of my stuff.
Page 1 of 2 12 Last
