Results 1 to 8 of 8
  1. SBCriss is offline Car Aficianado
    Default 360degree turn [help]
    Hi, can someone tell me how i can do an 360degree turn.
    Do I have to be in H-Mode, which car,....
    Thanks
    Instagram: crisseh95
  2. ShadowGT is offline I <3 Boobies!
    300C is probably the easiest. Pull the handbrake at a high speed & hard turn till your 180 degrees then hold the brake & the momentum of the car should keep you spinning. When you get to three quarters of the spin floor it & turn in the direction of the spin & it should straighten out. easier to do in some cars then others.
    Leader & Founder of the "Ponies of War" Gaming Comunity
  3. Mb
    Ferrari 575.
    Actually any car with rwd and engine in the front.
  4. Sponge is offline Spongify
    Best car is the Alfa GT 3.2v
    It's FWD so you can just floor it when you're 180* into the turn, and thanks to TDU's wierd physics engine, you will just spin around and continue straight.
    SOOAG - Smug Owner of a G27
    Winner POTW: Week 28, 53
    Proud Owner Of TDU's FIRST Manual Shift Gallardo
    Flickr
    ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ
  5. SBCriss is offline Car Aficianado
    Thanks guys but i did it with the McLaren F1
  6. -Lr-SpeedraceR is offline Car Aficianado
    I did it with a bike.
    j/k ^^
  7. a nugget is offline BNR34 FTW!!!
    audi a6/s6 are really easy to do that stuff in
  8. Andreas¹ is offline Crazy Duck
    I can't do it 'on purpose' but I do it in my Esprit sometimes when I hit the walls on the highways :P
