Results 1 to 7 of 7
  1. Agonist is offline Just a Skidmark
    Default Using existing TDU sounds
    Id hate to start a new thread about this but havent seen about it. Sorry if I did miss. I try and never make request. I cant get the Holden Effigy Concept Car sounds file to work with the Mustang GTR. I personally think that it would sound friggin awesomee on the GTR. I tried using audcity and reworking the sounds to be exact as possible as the GTR ones but cant get it to work. I would absolutely appreciate if someone could get the effigy sounds to work with the GTR.
  2. Sponge is offline Spongify
    Um. Rename the Efigy to the GTR file? Wouldn't that work?
    SOOAG - Smug Owner of a G27
    Winner POTW: Week 28, 53
    Proud Owner Of TDU's FIRST Manual Shift Gallardo
    Flickr
    ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ
  3. Immelmann is offline Custom User Title
    I would think it would work to rename it as well?
  4. Leadfoot[YT] is offline COTM Creator
    It depends on file sizes. To avoid this problem, download Djey's famous Magic Map.
    Oh, and if you like the TVR Sagaris, but thinks it needs a new sound, try my mod:
    http://tduaddons.com/tdu/sounds/tvr_sagaris::137/151/
    Recognize it from somewhere?
    -Leadfoot
    HittingRedline.com
    Quote Originally Posted by Ryzza
    ...Norton deleted it.
    Maybe you should return the favour to Norton.
  5. Agonist is offline Just a Skidmark
    I did try renaming it as well. Did not work. Thanks your reply. I shall give the Magic Map a try. Just used the Magic Map. It worked. Renamed the Effigy sound to gtrs, and bam much better gtr sounds. Thanks.
  6. Shy Guy is offline Car Aficianado
    The GR-1, Cobra Concept have the same sound, except it sounds a little bit better
  7. GF6200N00B is offline http://www.youtube.com/us
    maybe cutting GTR files helps???
