Results 1 to 5 of 5
  1. Leadfoot[YT] is offline COTM Creator
    Default Nissan GT-R on RS4 Body
    Since the camera position in the Spyker C8 is too low for the GT-R model, the 4WD Audi RS4 with more GT-R-like physics, and a much higher camera position, seem like better problem.
    Could someone please tell me what values to switch and what to switch them too in the TDU Modding Tools MAP Editor? Thank you!
    -Leadfoot
    HittingRedline.com
    Quote Originally Posted by Ryzza
    ...Norton deleted it.
    Maybe you should return the favour to Norton.
  2. Djey is offline Car Aficianado
    Seems you'll have to wait a little, since car body file RS4.bnk is not supported by the tools yet.
    That's to say I don't know what place to modify in bnk1.map to allow its replacement by another file (like GT-R one). I have to look for it manually.
    I'll go back here and update key.xml when done (not before Monday though).
    Give life back to TDU: #TDUForever
    Projects: TDUF | TDUMT | Community Patch 2.00A
    Buy me a beer (donate)
  3. EmKill is offline Mr.Stig B)
    Leadfoot[YT] good idea!
  4. Djey is offline Car Aficianado
    Done ! Now you can replace RS4.bnk with any file and TDU will accept it
    To do this :
    - download the last key revision (r152) :
    http://forum.tdu-central.com/showthread.php?t=3739
    - replace existing map-key.xml by this new revision
    - replace your RS4.bnk by renamed model of GT-R (for example)
    Then, start the Modding Tools :
    - either in File Browser, retrieve RS4.bnk file, hit CTRL+M (Map details) then fix it
    - or in MAP Tool, use 'Fix all' function.
    Please let me know if it works.
  5. Leadfoot[YT] is offline COTM Creator
    Wow! It works brilliantly! Thanks so much!
    The only problem is, now that I've got the camera in the right spot and the phsyics accurate (and a "GT-R" interior from another car).
    What's the solution to it? I know there is one, because BasBas fixed it on his LP-640
    -Leadfoot
    Attached Images Attached Images
    HittingRedline.com
