Results 1 to 2 of 2
  1. Colster is offline Rusted Banger
    Default Weird Connection Problem in TDU
    Ever since I have had TDU I have had a strange problem that I can't resolve.
    I never have problems connecting to the servers and when I look on the map every players is shown as a red diamond, players in game nearly always have a good connection and not too much hopping about at distance but whenever the session I am in goes over 6 players I am hopping about like mad to all the other players but they all still look fine to me.
    I was originally on 4Mb VirginMedia with a cable running up to my PC, thinking it was a router ports problem I changed my router to a Linksys from my original Buffalo one as that couldn't open enough ports but still the problem persisted. I have also tried plugging straight into the modem and removing the filter plugged into the back of it. None of this makes any difference.
    I recently upgraded my PC and changed mobo so now using a different LAN adaptor - still the same
    VM have recently also upgraded my connection to 10Mb - again no change.
    My download/upload speeds are consistent with what they should be for the package I'm on and I have no problems with anything else online - other games (TF2, DoD:S etc), uploading to FTP sites, web browsing, torrents etc.
    I was in TeamSpeak with a m8 for the last cruise I did and when that went above 6 ppl, I again started lagging and he said the sound was all choppy in TS too although I could still hear him ok.
    Any ideas?... cos I'm about all out
  2. S71NG3R is offline Car Aficianado
    There has always been a problem with stability when there are over 6 people in a session. But I have found the last few months have had major stability problems. Also using TS and Xfire can cause bigger stability problems.
    As gamespy run the servers there is not a lot we can do about it. Also the connection speed dose not seem to make any difference unless you have a really slow connection then you will lag almost all the time.
    TDUC PC Club find out more and how to join|Twitter @TDUCentralClub
