Results 1 to 9 of 9
  1. Brake Lights Mod
    Liquidsilk is offline Just a Skidmark
    I was wondering if someone could change the timing that the brake lights come on. In TDU, they only come on when the brake pedal is pressed more than 1/3 of the way, which is not realistic.
    Thanks.
  2. Brake Lights Mod Comments
  3. Andreas¹ is offline Crazy Duck
    Maybe, but it would require more than visual modding
  4. Nipper is offline \/ The REAL TDUCk \/
    I don't think it's possible to change it.
    I hope someone proves me wrong on that though
    Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.
  5. Liquidsilk is offline Just a Skidmark
    Well someone on the US forums by the name Detress managed to change the timing of the brakes screeching. So technically, it should be possible.
    http://www.ataricommunity.com/forums...d.php?t=643469
  6. Djey is offline Car Aficianado
    No, Detress has only worked on brake sounds.
    Moreover, no config file has been found yet concerning brake timing... most of the files are not readable even with an extractor.
  7. Nipper is offline \/ The REAL TDUCk \/
    I am willing to put money down that it isn't possible.
  8. DriftNismo is offline 87 Civic GT
    Of course it's possible, just nowone knows how yet .
  9. kuenzelde is offline Rusted Banger
    ya..i would likr it because i hate this "bug"
  10. Jozusi is offline Just a Skidmark
    Lightbulb Here goes what I did regarding that "bug"
    As I am brazilian and my logitech profiler is in portuguese, the menu names might sound a little bit different but it goes like this:
    * Access G25 Logitech Profiler
    * Click on brakes
    * Click on axis properties
    * Put brakes sensitivity on 0%
    Believe me, it doesn't make the braking range lower, it stills the same, but try it now, you're going to see that the timing for the brake lights activate is faster. Not 100% synchronized with the pedal, but way faster than before.
    Sorry for my bad english.
