Topic:
HDR
Page 1 of 2 12 Last
Results 1 to 20 of 32
  1. Speedtouch is offline I Wish I Was Special.
    Default HDR
    Right then. This is the (and my) first tutorial. I am basing it on the art of HDR.
    Now HDR is a wonderful process, and when used well, can give spectacular effects (see examples at bottom). However do not expect it to come easily. There are many different aspects, and many different processes you have to go through before you get a final photo, and even then, sometimes it can still be terrible (even I've suffered from this, so don't give up if you get it).
    The best way to do HDRs, is to shoot with RAW. Pretty much all DSLRs will do this, so all you need to do is find the Image Quality settings and set it to RAW. This is the process I will be covering now. I may do one for JPEGs later, but a quick RAW HDR tutorial for now.
    First things first, take your picture. HDR will bring out the darker details in the photo, so may not be entirely of good use, as this example proves:
    Remember this when taking your photo. There is a time and a place for HDR, and this wasn't it. Landscapes tend to be the best type, as this brings out reflections, like in water very well.
    Anyway, onto the processes.
    Once you have taken your photo and transferred it to your PC, you will need to sort it into the exposures (in the JPEG method, this is done by taking many different photos with different exposures - using a single RAW makes this very simple)
    Stage 1: Preparing for HDR
    Open the file into Photoshop (some people have had problems with this, but I didn't, so I'm not sure what goes wrong, or how to fix it. Post here if you have any problems and we will try to fix them).
    For now, we will only use the exposure setting. You can change it to what looks best (if the picture you took was dark, then increase it until the image looks normal) but its best to leave it alone for now. Then you need to change it to intervals of 1, starting at -2, going to +2. However if you changed it, keep the extra amounts in the equation. For example, if you decreased the exposure by 0.6, your intervals should be -2.6, -1.6, +0.6, +1.6, +2.6.
    Once you have changed the values of exposure (red box), you can save it (blue box). You need to do this for each value.
    This box should pop up once you click 'save' (not File>Save As). Change the location to a place where you will remember (red box), and change the File Naming to 1 Digit Numbering (use drop down list), and start it at 1. Finally ensure it is set to TIFF, as this gives a better quality (blue box).
    Stage 2: Making HDR
    Once you have done this 5 times, you can close down photoshop. Now open Photomatix (download free trial here - unfortunately the trial watermarks your final photos, so you can use it for practice, but to use it properly, buy it or PM me for a code).
    Open them up using the 'Generate HDR Image' (red box), and browse to find all 5 of the pictures. Put them into the list in order, then hit OK (blue box)
    Hit OK twice more, and then wait whilst it renders your image. When it loads, hit 'Tone Mapping', and it should look a bit better. This is your HDR image now, and all the tools to manipulate it.
    The way I do things from here onwards, is just play around with all the different settings. Once you have spent a short amount of time with it, you get to know what all the things do. Use all the smaller tabs, and all the sliders to change certain bits of it, and the curve works just the same as anywhere else. You can either use 'Details Enhancer', or 'Tone Compressor'. I prefer the former, and once you have what you want, hit Process. File>Save As and set it to .jpg to finish off.
    You can open it back up into photoshop and add some more final details if you want, such as borders etc, or just take it as it is.
    My finished example:
    Sorry this was such a bad tutorial, but it is my first I hope it helped you.
    If your camera does not take RAW:
    If you know how to take separate exposures with your camera (which doesn't do RAW), then use a tripod, and change it to something like -3 to +3 EV step (just like with the Exposure setting in PS). I'm not sure how this works, but in theory it should give you a load of images to then put into Photomatix, which is the key part.
    2 more examples of mine:
    I think maybe for the next one, it will be less of a tutorial and more of a tip giver to take a better photo, even with a 'point and shoot' type camera.
    PhOTW Week 8 + 15 | PTOTW Week 1, 4 + 5
  2. Mb
    Good tut.
    I did some HDR's before but they sucked. Might go out on someday to take some good photo's.
  3. Andreas¹ is offline Crazy Duck
    Great tut, will try it sometime ^_^
  4. ExplosiveGoats is offline Car Aficianado
    Good tut, could make some use of this.
  5. Iced_Bullet is offline Cheese=Milk's Death Route
    Nice!
    Mind if I post on Flux? Obviously with Credit
  6. Speedtouch is offline I Wish I Was Special.
    ^ Sure if you want to!
  7. RB26DETT is offline Banned
    i'll have to nick my sister's 450D to try this out.
  8. The Queen is offline <3 Ferrari F50
    Just tried this and the finished result is looking good
  9. Speedtouch is offline I Wish I Was Special.
    Was that with the process shown above or with the program?
  10. Mb
    #10
    I HDR'd 2 pics of me.
    I like them actually, one is more dramatic then the other, but that's how i like it.
  11. ExplosiveGoats is offline Car Aficianado
    #11
    The last one is stunning!
  12. Speedtouch is offline I Wish I Was Special.
    #12
    Great pics! Also - fail at counting. Clearly you didn't pay attention at school when they talked about a little thing commonly known as 'maths'.
  13. Andreas¹ is offline Crazy Duck
    #13
    Can't see any pics of him either.
  14. Mb
    #14
    Quote Originally Posted by Speedtouch »
    Sorry, when i wrote that i put 2 there, but i saw i had another 2 and forgot to change it
    Thanx for lovely comments <3
  15. Mb
    #15
    One more...
  16. KoenigseggBG is offline Made in 1994
    #16
    Oh...the 599 looks astonishing in white...
  17. Mb
    #17
    Hmm, im into HDR now.
    Some from Indonesia These are made around the Toba Lake on Sumatra.
  18. KoenigseggBG is offline Made in 1994
    #18
    Can I have the first one in hi-res, please...
  19. Mb
    #19
    Sure! Will do that on msn
    HDR is addictive.
  20. TDU 505 is offline Clinically Insane
    #20
    I have 2 requests!
    Martijn! Can i please have the last one in high res? That shot is brill!
    And, Speedtouch! Can i have your example shot? Brill shot too!
    Wow what a difference *snap snap* HDR makessssss
Page 1 of 2 12 Last
