Topic:
Help!
Results 1 to 10 of 10
  1. Creatix is offline Burnt-out Shell
    Default Help!
    hee,
    i have some problems with tdu
    first i have a problem with going online. i have an original tdu cd but my brother use the cd key and i was wondering. is it possible for me to go online with the same cd key if he isn't playing the game? i already tried but he keep saying that i must check my network thing or some:S
    and second i have downloaded a carpack from internet and if i go play on my account and i go out of my house, tdu doesnt work anyone and get stuck:S
    hope you can help me
  2. Iced_Bullet is offline Cheese=Milk's Death Route
    What do you mean stuck? Freezing on 'Saving, please wait' ?? Common problem, easily solved if it is.
    http://forums.eu.atari.com/showthrea...ghlight=radial
    And about the Key. You can use the same key, but not at the same time. However this does cause problems later on. I speak from first hand experience (however I wasn't doing it intentionally. *looks at Sensei*. Also, it's illegal for another reason ...
  3. Creatix is offline Burnt-out Shell
    oke i solved the online thing but i still get freeze at saving point and i don;'t have a radial file in that folder:S only cd key
  4. Speed is offline Can You Feel It?
    Alternate Solution, which I'm posting in every one of these theads Lol.
    HOUSE SAVE FREEZE.
    Quote Originally Posted by Speed »
    1. Go in game, let it load, don't click "Continue Game" Instead go to options, then Video Settings and put it on low deatil, no AA, no HDR etc. Resolution can stay as it is. Then close the game.
    2. Open TDU again, this time do click "Continue Game" Browse through your garage, look at your news etc in your house for about 1 min. Then close the game again without leaving your house.
    3. Finally go back in game and play as normal, you should now be able to leave your house
  5. Creatix is offline Burnt-out Shell
    well the problem is i don;'t have any houses i just started cause i played offline with a savegame from internet:P i begin at rent a car and stuff:P
  6. Creatix is offline Burnt-out Shell
    YEEEEEEEEEEEEEEEEEEEEEEE i solved both problems and i can play online now woehooeeee yeeaaa now i need some cash and a car(H) w00h000
    im happy
  7. Iced_Bullet is offline Cheese=Milk's Death Route
    If you and your friend are still using the same CD-Key, then it will cause some problems later on. When both of you try to log on, it'll kick one of you, as it recognises that you both are using the same Key. Also, when you finally decided you both want to be on together and one of you changes key ... your previous profiles will not work, as they're attached to your Key.
    This is coming from first hand experience, even though I wasn't the one who had to restart their profile xD
  8. Creatix is offline Burnt-out Shell
    well my brother doesnt play online so i don;t have to worry about it cause he always play offline but is it true that the servers aren't always availeble?
  9. 560BHP is offline Im not here
    yes its true, they somtime close em to check em, repair em evt.
    Returning from the dead!
    PotW #30 winner!
    But what is the point of writing things here when im barely online...
    http://www.youtube.com/user/MatchBreakers
  10. Creatix is offline Burnt-out Shell
    #10
    aah oke
