Results 1 to 8 of 8
  1. Syndycate is offline Stiggy!!
    Default Speed Challenge Missing
    Hey guys, my name is Syndycate. I have a problem. In TDU i unlocked all the roads and challenges and there all done EVERYTHING. Except for one. Its a speed challenge called Give Me Speed i cant find it ive only counted off 25 speed challenges but it says there are 26 WTF help me out bros.. thanks.
  2. t.
    t. is offline Retired
    Check the map I see it listed as speed challenge 10 in the key. Its just up from a diner, if you take the main road from just below the Ferrari/Maserati dealer.
    flickr
    Quote Originally Posted by DreadMetis »
    Then I woke up in France...
  3. Syndycate is offline Stiggy!!
    It's not there all the roads are unlocked and I could only count 25 challenges ONE IS MISSING IN THE GAME!
  4. t.
    I am / was Ace, so they must all be there.
    flickr
  5. ScaR is offline Speed Racer
    Quote Originally Posted by Syndycate »
    mine was errored, so I spawned where its supposed to be on the map and I found it was there, with screwed up stats. so try this. then it will(should) work.
  6. Syndycate is offline Stiggy!!
    Could you give me a screen shot of your map where Give Me Speed is PLZ
  7. Syndycate is offline Stiggy!!
    Alright The Carpack Fixed This Woot This Gam3 1s S0 L337
  8. rakslice is offline Just a Skidmark
    Quote Originally Posted by tWm. »
    I was having the same problem with the Lucky Day speed event... I could see the event in the standings under info along with a garbled record value, but it didn't show up on the map.
    So I looked it up in in the map you linked, and found that I could see it if I drove up to it. However, right after I tried to enter, the game immediately crashed.
    I then upgraded to 1.66a, and now it shows up on the map as an incomplete event, but when I try to enter, the game still crashes.
    I assume that the code to display the race record in the event info screen can't deal with the value properly, and the game crashes.
    Any suggestions for clearing that race's info without throwing out the whole save game?
