Topic:
Camels Mini
Page 5 of 9 First ... 34567 ... Last
Results 81 to 100 of 171
  1. Camel is offline Legendary Classic
    #81
    He almost crashed into me. He did crap himself when he heard my tyres sliding down the hill towards him.
    Maybe that's what made my car have a pee.
    Just ordered about 100 worth of parts too. Not sure when they'll get here though.
  2. Ryzza5 is offline .
    #82
    You should know how to brake better than ABS anyway? Haven't you ever done threashold braking before? It's actually quicker than relying on ABS since ABS completely takes off the brakes ~8 times per second to stop the wheels locking.
  3. Camel is offline Legendary Classic
    #83
    Knowing how to and being able to do it the first time you try are two very different things. This is the first car I've driven with no ABS and the first time I've had to break hard in it. And with me turning off a roundabout going down a wet hill, it just made it ever so slightly more difficult...
  4. Camel is offline Legendary Classic
    #84
    My car runs awesomely now. Cleaned the air filter and it's stopped the rattling noise when I accelerate and it lets me actually accelerate. Now I can do 25mph in first gear easily and it's still in the power band. Before it sounded like it was going to blow up doing 10-15 in first.
    It also sounds like a car now when I'm driving it rather than a tractor. Much faster too which means my MPG will plummet. >.<
    Just waiting for my anti-freeze and the new thermostat to fix the cooling, it's not good at that at the moment. The oil seal kit and suspension parts will be coming at the same time too.
    It's also brilliant in the snow, I could do hill starts on steep hills where even some 4x4s were struggling to get up.
  5. TIMELESS is offline Moderator
    #85
    Quote Originally Posted by Caemfl »
    Thin tyres Mellors.. thin tyres.
    #LETSMAKETDUCKGREATAGAIN
    Naturally Hans is wet, hes standing under a waterfall.
  6. The Compensator is offline Future heel&toe historian
    #86
    Quote Originally Posted by Madame Stella »
    And good tires... good tires.
  7. Camel is offline Legendary Classic
    #87
    They're wider than stock though!
    Also managed to slide it all the way around a car park roundabout as the minibus driver from worked laughed. Had quite an angle too, was right fun. xD until the speed bumps broke my back even at less than 5mph. >.<
    Even in 2nd gear if I put my foot down in snow it just digs in and grips as if it's just a bit wet.
  8. Ryzza5 is offline .
    #88
    Just don't drive near any walls
    Great to hear you've improved it
  9. Milli is offline An eternal apprentice.
    #89
    Nice little car. You still have the Focus though?
  10. Camel is offline Legendary Classic
    #90
    Quote Originally Posted by DarkAvenger »
    Yea, still insured on that too. Drove it a couple of days ago for the first time in a few weeks and didn't like it at all! There's just no feeling to it.
  11. Camel is offline Legendary Classic
    #91
    Great news. The absolute retard who last put the bottom hose on the radiator decided to do it the wrong way! So the hose clip screw points right at the bulkhead so it's almost impossible to get a screw driver onto it. He did this rather than making it so the screw pointed straight up to the bonnet between the bulkhead and the radiator.
    So my radiator is full of crap and doesn't work properly which means my car overheats rather quickly. And there's no way to fix it! Oh and I ripped my hand to shreds trying as the fan blades are rather sharp.
    All because of Rover in their infinite wisdom decided to remove the cooling system drain plugs from both the radiator and cylinder block.
  12. Camel is offline Legendary Classic
    #92
    Well all of my parts came!
    Although nothing at all went to plan. I broke a rather large, strong 12" monkey wrench compressing the suspension to get the old bits out. According to my brother it's because I went into hulk mode when doing it. He's bigger and stronger than me but he couldn't turn the big nut when I could.
    So I broke the wrench which resulted in it hitting the rocker cover and me falling flat on my arse. I think I'm going to pay to have it done at a garage as I injured myself doing the safe easy bit. The next part was where you can lose fingers or eyes if the compression tool breaks.
    I also broke my new screwdriver trying to get a bolt from the radiator bracket with the socket attachment on it. The bolt is pretty damn corroded and it's the wrong size for the hole...
    So all in all I broke my 2 most expensive tools, fell over and accomplished nothing in an entire day. =D
    Still love it though, awesome little it.
    E: Oh, it also starts first time in -7C within a second or two after it's not been started for days which is pretty damn good to say it's which the thick oil. It starts quicker than my dads car in the cold and that's over 20 years newer.
  13. Jacob is offline Car Aficianado
    #93
    You need to buy yourself some rust penetrate really helps with corroded parts. It has saved me many a skinned knuckle, and my tools from flying across the room. Glad to see the little Mini's coming to life
  14. Camel is offline Legendary Classic
    #94
    I'm gonna ask the garage to try one of their power tools when I take it in for the suspension. They offered to lend me some tools so I could do the suspension at home so I don't wee why they'd say no.
    And I would do it at home, but I value my fingers too much. If the compression tools breaks when I'm taking the trumpets and knuckle joints out I'd lose some fingers.
    His face fell off.
  15. TIMELESS is offline Moderator
    #95
    Quote Originally Posted by Cmfl »
  16. Camel is offline Legendary Classic
    #96
    See, wee, what's the difference? *shrug*
  17. TIMELESS is offline Moderator
    #97
  18. Jacob is offline Car Aficianado
    #98
    And I would do it at home, but I value my fingers too much. If the compression tools breaks when I'm taking the trumpets and knuckle joints out I'd lose some fingers.]
    With air tools. Its extremely important to use the proper impact sockets. You can't just use regular chrome sockets. But once you have the correct sockets theres really nothing to worry about. I use compression tools everyday and have never had anything shatter or break. Sorry if it sounds like im always trying to shove advice down your throat. Just trying to be helpful.
  19. Camel is offline Legendary Classic
    #99
    I managed to free the seized bolt myself. Eventually.
    I used somebodies hair dryer on it *cough cough*, let it cool down a bit and then used my screw driver with the right socket on the end, stuck another screw driver through he end of mine so it was sticking out sideways then slowly wiggled it and it eventually came free.
    Managed to get the radiator out and flushed the entire cooling system. Was shocked at how much crap actually came out of it. Got the radiator back in but it was too dark to tighten up the bottom hose properly. Hopefully going to get it finished off today so no more overheating! *crosses fingers*
    Also learnt not to try and flush the engine block when the thermostat is in, the water won't get past it as it's closed and it'll just squirt back out the hose and cover me.
  20. Ryzza5 is offline .
    #100
    Learning is lots of fun ain't it?
Search Tags
camels
mini
rip
