Thread: HELP
Results 1 to 5 of 5
  1. BBULL is offline The Fastest of the Slow
    Exclamation HELP
    SO i haven't played TDU for a few good months so I decide to ride around. wouldn't you know that I can't play offline like I want to.
    I keep getting this message that says
    "The gamer profile contains DLC that is no longer available would you like to connect to XBL marketplace"
    What do I do. I believe it has something to do with DLC #5.
    what do i do?
    I discovered the Hennessey Viper SRT-10 Venom 100 on 4/14/2007
    http://www.leagueracers.com <-- I am Starting a Gumball rally type tournament on it and its a brand new website. Just keep in touch lol. Also throw around some ideas.
  2. Diablo is offline I'm Delicious!
    Have you had the 3RRoD lately or bought or received a refurbished console?
    I'm a bit mental.
  3. BBULL is offline The Fastest of the Slow
    yes i got a new xbox from the factory factory. when it got the 3RLoD. I kept the hard drive and it should be ok but what is.
  4. MaDaSp7 is offline 1993 - 2003
    This may help, it was posted by woodsteruk on Atari TDU forum.
    Quote Originally Posted by woodsteruk
    Transferring DLC packs to new XBOX
    For those of you suffering from the same problem as me, I've discovered a way to use your profile and downloaded content on a new xbox 360 after your old dies on you.
    After putting my HDD with downloaded content and profile onto the new machine, I also suffered from the problem of downloaded content not being available due to it being locked to my old one's serial number.
    Anyway, once playing the game go to the 'trade' pagef rom your house and select the 'market place' option. All the content that you've downloaded will be there, so if you select it you'll get the option to download again, change storage device etc. If you select 'change storage device' and just select the harddisk again, then it re-enables the content without actually having to re-download it.
    Hope that helps some people out.
    I have the same problem, unfortunately it means you will now only be able to play TDU while you are online. Also if you have purchased hardcore mode you may also need to start TDU a couple of times before you can use it.
    "Risk it for the biscuit, as my dad says" - Lewis Hamilton
    "If you make a car too adjustable people fiddle with it and most drivers haven't got a clue what they're doing" - Gordon Murray
  5. BBULL is offline The Fastest of the Slow
    Thank You. I'll try that
