Results 1 to 10 of 10
  1. Sultan is offline Burnt-out Shell
    Default Help! Installation problem!
    I bought TDU for PC today (I wanted Ferraris), and so I'm installing normally. But at the last moment, an error comes up. It says that it couldn't find Manual.BG, and verify that I could see and access it. Any help?
    I play, these racing games:
    1. GranTurismo 4
    Oh come on, let's be honest. GT4 has 720+ cars, 50+ tracks, and the best graphics.
    2. Test Drive Unlimited
    Koenigsegg! Honolulu! Speed! I love TDU.
  2. The Queen is offline <3 Ferrari F50
    My only advice is to maybe try again? Tell me if it helps..
  3. Iced_Bullet is offline Cheese=Milk's Death Route
    Yeah, uninstall the game AND the patch (if you installed that)
    Try here for a detailed uninstall and install process http://forums.eu.atari.com/showpost....45&postcount=1
  4. Sultan is offline Burnt-out Shell
    Technically, I had never installed the game. At the last bars in installation, the error appeared. All files that had been copied were kept, but I don't think the game was completely installed. I deleted all its files, but the ones it said in the link were never there (Yes, I can see hidden files). So I just re-did it.
    How do I find the patch? What name does it have?
    1. GranTurismo 4
  5. Iced_Bullet is offline Cheese=Milk's Death Route
    Have you downloaded the patch? then you need to open the folder of the patch, then click on the icon to install (the only one which isn't a word doc I think)
  6. Sultan is offline Burnt-out Shell
    http://img76.imageshack.us/img76/6668/dibujoss2.jpg
    There's a screenshot.
    I haven't downloaded anything. I just bought the game, came home, and immediately installed the game.
    1. GranTurismo 4
  7. Iced_Bullet is offline Cheese=Milk's Death Route
    Ah... Sorry I have no idea what the problem is
    If you post this to the official attari forums' PC Tech Help, then you should get some sort of solution, if not, they'll refer you to the Official Atari support team.
    http://forums.eu.atari.com/forumdisplay.php?f=459
  8. Sultan is offline Burnt-out Shell
    Well, thanks. I registered and posted it. Thanks for the help guys.
    1. GranTurismo 4
  9. buttsneeze is offline Burnt-out Shell
    It doesn't seem to be a file that you need to run the game, so you can probably just go ahead and start it (use the .exe, it probably didn't make a shortcut)
  10. HavockJoker is offline PGR4 Master
    #10
    How about you go try and find the pdf online. Put it in the folder that TDU is being installed in, and see if that works. I don't know if it will work but give it a try.
