Thread: Video Help
Results 1 to 15 of 15
  1. Iced_Bullet is offline Cheese=Milk's Death Route
    Default Video Help
    The video starts out very nicely, but then 1/3 of the way through starts to stutter, and the sound quality goes... and from then on it deteriorates... Please can someone help
    If the video above doesn't show click here to view it.
    I was only running TDU and Fraps at the time...
    Not sure if this is the right section, as it's help I need...
    And if this is the wrong section I wouldn't be offended if this thread was deleted, as I'm not sure where to put it
  2. eleKtro is offline Contain Your Orgasms
    Sorry, but how can you record for so long? You bought fraps I take it?
  3. Mb
    Do you have enough space on your harddisk?
  4. Iced_Bullet is offline Cheese=Milk's Death Route
    Quote Originally Posted by MadMax »
    ofc well i wasn't actually me :P
  5. Diablo is offline I'm Delicious!
    Hmm not used FRAPS myself but what kind of compression if any does it use? Also try recording a minute long video and see how big the file is this will give you a god idea of how the video is being recorded. Only thing I can think that would cause this is memory or hard drive space becoming an issue.
    This is the right place for your thread so the other one has been removed.
    I'm a bit mental.
  6. Speed is offline Can You Feel It?
    Quote Originally Posted by Iced_Bullet »
    It was me! Sort of... Lol.
    The filesize is big because there isn’t enough time to encode the movie while the game is running. The movie frames are slightly compressed, but still require a large amount of disk space due to the high resolutions. Once you have finished capturing you should convert the saved AVI into one of the popular compressed movie formats such as mpeg or divx.
    http://www.fraps.com/faq.php#videocap
  7. Mb
    I have this video, about 5 minutes. 1GB +
    Fraps makes hhhhhuuuuuggggggeeeeeeeeee video's.
  8. Diablo is offline I'm Delicious!
    Quote Originally Posted by MartijnMb. »
    That's nothing my caps are 0.5Gb a minute thus 5 minutes is 2.5Gb. Though I don't have a game and video encoder using my memory, hdd and graphics card while doing so.
    If you record without capturing sound is it any better ?
    I'm a bit mental.
  9. Iced_Bullet is offline Cheese=Milk's Death Route
    Thanks for the link Ross It's helpful
    Plus diablo, I'll try not recording the sound, plus ill lower the FPS, because it was recording at 60FPS when my ingame was 30FPS.... So I'll lower that...
    But not tonihgt, getting an early night because GCSE results are out tomorrow
  10. eleKtro is offline Contain Your Orgasms
    #10
    Every time I try recording with Fraps, it records fine perfect picture but I get no sound from my video when I play it?
  11. Pherelas is offline I'm Going Slightly mad
    #11
    http://www.smallvideosoft.com/screen-video-capture/
    Was looking for a dvd ripper and found this, anyone use it. No used to me as I don't use PC for gaming but thought I would post it. Sorrys if this is well known or rubbish.
    [imglink]http://i147.photobucket.com/albums/r289/pherelas/SigCustom.jpg[/imglink]
    . . . . . . Why is it always a wrong number, what if there in the wrong house? . . . . . . .
  12. ///AMGedUP is offline Sportscar Racer
    #12
    if you want sound, just check "record sound" under "movies" tab in fraps, also if you want your recordings to come out smooth, check 60fps under "Movies" tab as well
    if your fps suddenly drops down to like 5 while you are recording, just rerecord
    if you still get that lag then you prolly dont have enough room on your HDD, remember fraps files come out big so you prolly wont notice your HDD space is being eaten, unless you have like a big HDD
  13. Iced_Bullet is offline Cheese=Milk's Death Route
    #13
    Quote Originally Posted by ///AMGedUP »
    Yeah the HDD is 250GB and only 50 is used :P so that's unlikely! haha.
    Yeah thanks, to recdue the file size i record on 45FPS now, as my game only ever goes up to 43 in the country side.
    In the video up top, I did use 60FPS to record. :P I was getting 13FPS when recording that one, and ive reduced EVERYTHING except resolution and Refresh in my graphics card control center aswell, so I know see 20FPS when recording -in game but records at 45 so a smooth picture woot!
    EDIT: my 118th comment xD yaya!
  14. ///AMGedUP is offline Sportscar Racer
    #14
    doesnt matter if you lag while recording at 60fps, ur recorded footage should run at 60fps, unless u get like lag spikes while recording
  15. Iced_Bullet is offline Cheese=Milk's Death Route
    #15
    Well I was down at 13FPS when it was first recording, which recorded at 60FPS, so that was fine, and then it deteriorated down to 5FPS, and the sound went, and as you can see from the second half of the vid ^ it did record lag!
