Results 1 to 9 of 9
  1. iBilo is offline ;)
    Default TDU Disc problem?
    For some reason lately, I've loaded TDU and when you press Continue game, it loads. As the house comes up, it freezes and says 'Disc Error', I've checked my disc and it has a few scratches but I've noticed like a scratch blob on the disc, should I use the toothpaste method on this or should I chuck it away and buy a new TDU?
  2. Nodz86 is offline ____________
    Toothpaste all the way mate. Thats exactly what mine was doing, then I done the toothpaste trick and its worked fine ever since
  3. cocoki700 is offline Speed Demon
    tooth paste and hair conditioner than good old spit shine
    [SIGPIC][/SIGPIC]
    The demon within me is Speed
  4. Pherelas is offline I'm Going Slightly mad
    I've been using the toothpaste, did it once, worked for about a month and have just done it again but kept in for about an hour.
    [imglink]http://i147.photobucket.com/albums/r289/pherelas/SigCustom.jpg[/imglink]
    . . . . . . Why is it always a wrong number, what if there in the wrong house? . . . . . . .
  5. khevolution is offline Most likely To Hit a Tree
    what is this toothpaste trick? can't be arsed to search for it, too early in the morning
  6. Nodz86 is offline ____________
    What I done was put a dollop of toothpaste on each scratch then rubbed it in a circular motion to spread it, then leave it to dry (becomes hard). Once it has dried, wash it off with cold water under a slow running tap. Then once it has dried buff it to a shine with the cloth you get with the PSP (Or a cloth for cleaning glasses will do).
    It should then work.
  7. iBilo is offline ;)
    The toothpaste trick worked and my TDU goes like a dream, ty.
  8. Koenigsegg is offline Meh.
    Quote Originally Posted by Nodz86 »
    i lost the cloth i got with my psp.. or maybe i just can't find it
  9. Tuph is offline Drifting Ledgend
    i'll be sure to try this when my game doesn't work.
    :bananasplit:
    Current bank: $0
    Current fines: $350,000
    RUF TURBO !
