Page 1 of 2 12 Last
Results 1 to 20 of 30
  1. FA430RGT is offline Hoods and Alley-ways..
    Default Just got the 3 Red Lights!! (Have a read it may help)
    Just turned the 360 on and to my horror the 3 red lights (of doom) started flashing.. I've currently using the in-famous "Towel trick" (Google it to see what I mean) and hopefully (by some miracle) the 360 will be fixed.. As I'm writing this I have noticed a few strange rather recent events whilst playing on the 360.. The most recent is whilst playing any game really the console crashes.. The screen sort of turns into a diagonal form of the game before it happened. However about and hour ago (if that) I left the 360 on and came to the computer and when I returned it had crashed on the marketplace blase (I had left it there) and it was just when I had finished a download as the little Icon saying "So and So has just been downloaded" was imprinted at the bottom and wasn't going. So like anyone else I just turned it off and left it to watch some normal TV..
    Be Warned I have started shifting pictures from a little pen drive as my background wallpaper very recently and I'm not sure weather or not it ended up playing a part in the presence of the 3 Lights.. I'd say it's been about 3 minutes I've been writing this message I will write to you lot again shortly once I finish the "Towel Trick" and tell you what future actions I will have to take because of this... And all I can say is.. What a timing!! Oh and last and probaly most important is a huge increase of useage for the pass couple of days aswell which is possibly had a factor aswell!! Also tips on what to do are nicely requested! Also past experiances would be nice..
    EDIT----------- (After about 20 Minutes)
    Just removed the towel and and placed 360 ready to press the button. As I did the screen started up as normal for about a second at the most before cutting out and we have a result! My console is now only displaying 2 Red Lights instead of 3 (great).. I'll check back here in about 25 minutes I've just disconnected the power supply and am now letting the 360 cool down..
    EDIT (x2)------------ (Aftermath)
    Well it appears that the internet has once again proved its worth and it seems all is well.. The temperature is back to normal it has started up and run normally before I turned it off (by choice) and I will keep in touch with this thread if problems arise)..
    ALSO: 1500 Post wOOt!!
    ...I Still Dawdle Round These Ends...
  2. Baldy is offline Wibble Wobble
    Oh Nooooes!!!!! Not your 360, well my friend did the towel trick and it worked, But not for long his 360 is now at ms and could be there for 25 more days.
    Another insightful post by Baldy!!
    "Life is like a slush puppy, the longer you leave things the more they melt"
  3. FA430RGT is offline Hoods and Alley-ways..
    Here a referance for those who don't know what the lights mean.. Made very clear for you
    Xbox 360: Two red lights flash on the Ring of Light
    SYMPTOMS
    The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console.
    CAUSE
    This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on.
    Xbox 360: Three red lights flash on the Ring of Light
    SYMPTOMS
    You see three lights on the Ring of Light (RoL) flash red on the front of the Xbox 360 console. The upper-right quadrant light is the only light that does not flash red.
    CAUSE
    This behavior occurs when the Xbox 360 console experiences a hardware failure.
    Xbox 360: Four lights flash red on the Ring of Light
    SYMPTOMS
    All four lights on the Ring of Light flash red on the front of the Xbox 360 console.
    CAUSE
    This issue may occur if one of the following conditions is true:
    The audio-visual (AV) cable is not correctly connected to the Xbox 360 console.
    The cable is not being detected by the console. This issue is not caused by incorrectly plugging the AV cable into a TV, a stereo, or a VCR.
  4. Diablo is offline I'm Delicious!
    Ahh check all your cables first, if nothing, then you have an issue so phone Microsoft, the 3 red lights of death problem is expanded to 3 years in the warranty and the work is done free including pickup and delivery.
    I'm a bit mental.
  5. FA430RGT is offline Hoods and Alley-ways..
    Quote Originally Posted by Diablo »
    I will do in about 10 minutes because I want to be 100% sure nothing can be done by me because its going to take soo long with the whole repair deal.. Plus I have some.. Missing stickers on the console which might be a minor problem but I've just had a good friend running the whole return process with me and the 3 year extension aswell!!
  6. The Queen is offline <3 Ferrari F50
    Good luck with that mate, hope it goes well for you
  7. Nodz86 is offline ____________
    Your not the only one, mines been playing up loads lately aswell, the disc tray doesn't always want to open, normally when I first turn it on, Fifa always freezes and says disc read error when someone lquits a match or makes subs (the sub one is occasionally), Its put a 3/4 inch crack on Saints Row fom centre of the disc outwards, Scratched Crackdown when I first got it and now TDU and it loves saying when I boot up a game please put this game into a 360 console or it justrdoesn't load the game and just stays on the dashboard spinning.
    If it is over heating alot of people aim a desk fan at it to try and keep it cool. Don't bother with them aftermarket coolers as some of them have been known to alter the current and cause very small spikes which the 360 detects it and it then crashes.
    Hopefully its just being a bit temperamentle which mine does, sometimes it'll work for weeks and be fine other times it'll be a pain for ages. If not at least M$ has extended the warrenty but then you run the risk of getting a recon/banned unit back on which your DLC wont work.
  8. iBilo is offline ;)
    Quote Originally Posted by Nodz86 »
    That's been happening to me lately! It doesn't open when I press the button and when I use my controller to open it it opens.
  9. FA430RGT is offline Hoods and Alley-ways..
    I see what you mean fellas.. Recently my disk tray has been abit slow to respond to my calls!!
  10. iBilo is offline ;)
    #10
    My 360 has been freezing lately, whenever I play on TDU and no other game. I finally got it working but it frustrates me.
  11. SupermAnthony is offline Man Of Steel
    #11
    I too have the 3 lights now! No problems with my 360 and now this happens. Just over a year old too...
  12. Nodz86 is offline ____________
    #12
    Quote Originally Posted by SupermAnthony »
    Your lucky that they have just extended the warranty for 3 years as you would have had to pay to get it fixed or buy a new one.
  13. SupermAnthony is offline Man Of Steel
    #13
    Have they really? That's a good job! I would've waited for the Elite I think, rather than buy one of these though...
  14. Nodz86 is offline ____________
    #14
    Yep, it got announced a few weeks back around the time of E3
  15. FA430RGT is offline Hoods and Alley-ways..
    #15
    Thats quite an interesting point.. I never thought of getting an Elite if my current 360 went down.. I believe I got my about 2 years ago now..
  16. Speed is offline Can You Feel It?
    #16
    I know I should really be creating my own thread, but I was thinking about getting a 360 until I read this thread and found out about all your problems. Do you recommend it, or is it just a waste of money beacuse it seems like a lot of hassle to me? Thanks
  17. Nodz86 is offline ____________
    #17
    Quote Originally Posted by FA430RGT »
    Trouble is if you go down that route you cannot transfer any DLC the units as all DLC is lock to the consoles code so you either have to try and get your points back off M$ or you have to buy them again.
    Quote Originally Posted by Speed_Freak »
    In the words of Clrkson describing an Alfa Romeo "They always break down or things always go wrong but when it all works its the best thing ever".
    That qoute may not be exact but he says something along those lines.
  18. SupermAnthony is offline Man Of Steel
    #18
    This is the first problem I've had with my 360. I've had it 14 months and it's never done anything major like this.
    As for Nodz's other post about DLC being locked. Does that mean if I get a refurbished console back I have to go through all the hassle of getting my points back?
    By the way, +rep for Nodz. Thanks, man!
  19. Nodz86 is offline ____________
    #19
    Unfortunately yes and theres a new problem aswell. It used to take 3 weks from when you sent off your console to get it or a recon back but now they have blocked modded, chipped, flashed 360's from using live all them people have been sending them in to get them fixed and getting a recon back which ment other people where getting a blocked 360 back so the time it takes to return a 360 has gone up as they have to get them unblocked.
    thanks for the rep.
  20. FA430RGT is offline Hoods and Alley-ways..
    #20
    Well the 3 red lights have struck again this morning so i'll most likely be calling microsoft later today if not tomorrow as I have plans tonight.. I'm doing the Towel Trick again but this will porbaly be my last time doing so as I don't think it's too healthy for the system..
Page 1 of 2 12 Last
